How to resolve Google drive connection issue with the older versions less than 5.0
For packages less than 5.0 steps followed to resolve the issue:
1. Add lighting Page URL and classic VF page URL in both Trusted URL and Remote site settings.
Getting the Classic URL : Switch to the classic UI of Salesforce , Open XfilesPro Application in classic mode and copy the domian url like below and share this URL to support@xfilespro.com
2. Upgrade package to greater than 5.0.
3. Configure new storage setup. (If GDrive is used the files in salesforce will be synced back ).
4. Reconfigure all objects one by one.
For other Storage types follow the refresh token steps after the upgrade.
Related Articles
Google Drive Configuration [8.4]
Google Drive Setup Guide – Step-by-step instructions to configure Google Drive for XFilesPro, including project creation in Google Cloud, app registration, OAuth credential generation, API permissions, and connecting the Google Drive account to ...
How to Resolve the Refresh Token Issue when Site Name is not showing
When the connection is lost and the site name is not displayed when we select Manage under Storage Setup, please go to the attached document and follow the instructions to configure the site name. Incase any issues or further assistance please reach ...
How to resolve the tagging issue with Invalid Request while updating the tag valaues?
when the user is trying to update the values of tags, it throws an error of "Invalid request" in that case to resolve the issue follow the below setups: Open Dev console --> query = 'SELECT Id, Name, XFILES__Tagging__c FROM ...
How to resolve the rename trigger deployment issue when customer had the other trigger on update
Steps to resolve this: Create a Org wide custom setting with the name MyOrgWideSetting (you can use any custom name) and click on save, Open the respective custom settings which have been created above and create a field (Enable_Trigger)with Checkbox ...
How to resolve the component issue for the Internal User/Standard User/ Non-system Admin User
The attached screenshots show whether it is a component issue or not. Resolution Steps: 1. Missing the Field-level Security permissions to the Folder Structure. Steps to activate the FLS Permission: 1. Select the object from the object manager. 2. ...
